You might be able to access wires, hinge side of passenger side door? There may be a protective covering, rubber boot, sometimes you can pull the boot back far enough to access wires. Pink wire is voltage, goes hot when you turn on the key. If you use the switch in the driver door, those other two wires, one on each side of the pink wire, are grounds, one ground for up and the other down, those two wires go to the master switch. The way the master switch controls the passenger window is a little different. I can't help you with the door panel, I always break something.
![https://www.2carpros.com/forum/automotive_pictures/512072_century_power_window_1.jpg](https://www.2carpros.com/forum/automotive_pictures/512072_century_power_window_1.jpg)
SPONSORED LINKS
Saturday, April 24th, 2010 AT 10:33 AM
