turn signal lens
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
CGBOWLES
How do I get to the front (driver side) turn signal bulb to replace it?
Dec 29, 2007 at 7:16 AM
FAIRRACING31
  • 150 POSTS
1. On some models you will need to remove the headlight bezel mounting screws and the bezel 2. Remove the mounting screws for the lamp assembly Remove the mounting screws securing the lamp assembly
https://images.2carpros.com/forum/automotive_pictures/103836_1_1.jpg
3. After the screws are removed, pull the assembly from the vehicle Pull assembly from vehicle
https://images.2carpros.com/forum/automotive_pictures/103836_2_1.jpg
4. Disconnect the twist lock socket from the lens housing Disconnect twist lock
https://images.2carpros.com/forum/automotive_pictures/103836_3_1.jpg
5. Remove bulb and replace
https://images.2carpros.com/forum/automotive_pictures/103836_4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/103836_5newer_1.jpg
Newer models have the turn signal separate from the headlight assembly. Hope this helps, have a Great New Year's :D
May 21, 2021 at 8:31 AM
