I'm not sure the picture worked. The tps should be located on the throttle shaft at the throttle-body. Three wire connector.
Have you tested it or anything?
Sep 26, 2008 at 3:49 AM
KINKER
MEMBER
IT is under the throttle body it is a lot easier to replace if you remove the throttle body itself . a little more work maybe but a lot easier
