1989 Buick Century dash board
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOKER80401
How do i get to my radio to replace it
Sep 14, 2010 at 2:39 PM
JALOPYPAPA
  • 467 POSTS
With a 7mm nut driver, remove the kick panel and the cover over the map light and rear window defogger switch (screw is at bottom). Pop out the cover. Remove the instrument cluster bezel cover with phillips screws. Unbolt the radio and pull it straight out. Wiring pigtail and antenna lead are in the back.
Sep 23, 2010 at 7:15 AM
