1989 Buick Century car cutts off
89,005 MILES • 6 CYL • FWD • AUTOMATIC
FX007
hi, I have a 1989 buick century custom with 3.3L engine. Now, my problem is all about the car's shutting offs after it's been driven for about 20 minutes. I already consulted some techs and so I changed everything they suspect that's causing the problem. Fuel pump is new, tps is new, AIC valve is new, ignition switch is new, and also I have changed the ignition coil, and lastly, I tried changing the ignition module with a used one but there is no change. the car still stalls. I just don't know if the ignition module that I got is defective. I there something that I missed that's causing the engine to shut off?
Sep 23, 2009 at 12:53 PM
  • 110,248 POSTS
Is the car oing the exact same thing? If so, I doubt the ignition module is the problem. When this happens, does the car start right back up? If not, have you checked to see if the engine is getting spark and fuel?
Sep 27, 2009 at 1:48 PM
