1989 Buick Century
130,000 MILES • 6 CYL • FWD • AUTOMATIC
SUSAN POWERS
how do i replace the heater core?
Dec 29, 2007 at 6:44 AM
FAIRRACING31
  • 150 POSTS
1. Disconnect the negative battery cable and drain the cooling system. 2. Disconnect the heater hoses from the heater core inlet and outlet connections in the engine compartment 3. Inside vehicle, remove the lower instrument panel sound insulator 4. Remove the heater floor outlet duct screws or clips and remove duct
https://images.2carpros.com/forum/automotive_pictures/103836_heat1_1.jpg
Remove the heater floor outlet screws
https://images.2carpros.com/forum/automotive_pictures/103836_heat2_1.jpg
.....then remove the heater floor outlet duct 5. Remove the heater core cover by removing the attaching screws and clips 6. Remove heater core cover 7. Remove the heater core retainers and remove heater core.
https://images.2carpros.com/forum/automotive_pictures/103836_heat3_1.jpg
Remove the mounting bolts which retain the heater core.
https://images.2carpros.com/forum/automotive_pictures/103836_heat4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/103836_heat5_1.jpg
https://images.2carpros.com/forum/automotive_pictures/103836_heat5_2.jpg
Heater core Have a GREAT New Year's :D
Dec 29, 2007 at 4:45 PM
