1987 Buick Century fuel issue
CJREED
  • 1987 BUICK CENTURY
Engine Performance problem
1987 Buick Century 6 cyl Two Wheel Drive Automatic
I have changed everthing I can think of for this century and I am stumped. I put in a new fuel pump problem never changed. I have put in the following used parts, ignition control module, ecm, the tps, and I am still haveing the same problem. The vehichle is acting like it is starving for fuel. When I put my foot on the gas it want's to die. What else could be the problem?
Tuesday, July 22nd, 2008 AT 2:06 PM
KLSHIEL
  • 163 POSTS
Have the fuel pressure checked at the engine. If this is ok and all the injectos aren't clogged or stuck your fuel system is fine. Check the air filter to make sure it is not clogged and run some intake cleaner through the intake. A plugged exhaust can cause this as well.
Tuesday, July 22nd, 2008 AT 2:32 PM
