1987 Buick Century Brake Lights and Hazzard Flashers
78,090 MILES • 6 CYL • 2WD • AUTOMATIC
BONIFACE4JESUS
I have a 1987 Buick Century, and somehow, when I have the hazzard flashers on, they flash like they should. However, when I step on the brakes, the hazzards stop flashing until I release the brakes. Is there a way to correct this. It seems unsafe to not have the hazzards flashing when they are needed, while pressing on the brake pedal.
Jul 19, 2010 at 3:29 PM
Inspect and test the directional/hazard switch
Jul 19, 2010 at 6:27 PM
BONIFACE4JESUS
rasmataz, what do you mean Inspect and test the directional/hazard switch. If you are referring to the idea that something could be wrong with the flasher can, that does not make sense.
The flashers flash like they should, except for when I apply the brakes.
Jul 20, 2010 at 2:50 PM
I know the difference between the flasher unit and the dir/harzard switch how its suppose to function I've been doing this for 41yrs
Some systems are make like that when you step the brake it pause the flasher there's a way to bypass this problem
Jul 20, 2010 at 5:50 PM
BONIFACE4JESUS
Thanks for the information. I will print this string of communication out, and bring it in to the shop soon.
The last time I was there, they were telling me there is nothing that could be done, and I figured that can not be correct.
Jul 21, 2010 at 8:38 AM
Its gonna cost to fabricate it, just hope they know what they doing, you have to be good in elecrcial to do such thing
Jul 21, 2010 at 10:13 AM
