1985 Buick Century engine stall while driving
STDELNPAI
Engine Performance problem
1985 Buick Century 4 cyl Front Wheel Drive Automatic
can you help me. when i am driving and the engine has warmed up (approx 20 min) the car just stops and it wont start up again sometimes for about 1 Hour or more. Do you maybe have any suggestions about what i should look at?
Sep 2, 2008 at 11:23 AM
  • 75,988 POSTS
Do below when it dies out and tell what's missing
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 2, 2008 at 11:29 AM
