1976 Buick Century Power Window relay location
185,000 MILES • V8 • 2WD • AUTOMATIC
DOUGJ
Where is the power window relay located? I've looked on the engine firewall and don't see (recognize?) it.
Jul 5, 2009 at 9:42 AM
MERLIN2021
  • 17,250 POSTS
I came up with the left shroud side panel...ALL except Caddy.
Jul 5, 2009 at 10:15 AM
DOUGJ
[quote:def9cd1758="merlin2021"]I came up with the left shroud side panel...ALL except Caddy.[/quote:def9cd1758]
I searched the left inner fender and there is no relay mounting. Have you another suggestion?
Jul 6, 2009 at 9:43 AM
MERLIN2021
  • 17,250 POSTS
Shroud is normally the radiator area, try there.
Jul 7, 2009 at 2:23 AM
LOUT5369
  • 217 POSTS
As crazy as this sounds,I have found the power window relay under the drivers seat,do you have power seats,alotta times GM will mount it there and tie in the 12v power supply to the power seat circuit.let me know if this helps
Jul 21, 2009 at 2:19 AM
MERLIN2021
  • 17,250 POSTS
Thank god someone else has still got a '76!
Jul 21, 2009 at 8:54 AM
LOUT5369
  • 217 POSTS
Glad I could help,I was a Buick tech for 10 years
Jul 21, 2009 at 9:46 AM
MERLIN2021
  • 17,250 POSTS
When did you give it up?
Jul 21, 2009 at 7:54 PM
LOUT5369
  • 217 POSTS
I stopped being a tech in November 08,I got bored with workin flatrate in 02,I went to a bodyshop and was a Mech/assembler,then I tore my r/rotator cuff,had surgery,went back to work and 4 months later broke my l/elbow on an 01 VW jetta VR6 and ruptured the disc in my lower back,Dr said I can go back to work as long as I'm not a auto tech anymore.My mom had a 75 Electra 225,it had some issues,that was one it had.I have a 1969 Impala Custom 427cu.in. 390hp with a worked Powerglide,and 373 posi,I built it from the ground up.The rear Lic.plate frame says" REAL MEN BUILD THEIR OWN CARS". I have worked on cars since 1971,dealers since 1975.
Jul 21, 2009 at 11:12 PM
LOUT5369
  • 217 POSTS
My favorite quote"Paint will not make a car go any faster"
Jul 21, 2009 at 11:15 PM
