Buick
100,500 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
JAYSON360
  • 13 POSTS
Car will start and run for about a minute. It's almost like it grounds out and I lose everything. I thought the altenator wasn't charging so it was replaced. Didn't fix it. I checked fuel pressure and there was literally nothing in the fuel rail when I purged it. Car will start if I hold it to the floor but when I let off it cuts off. Sometimes it loses power. Fuel pump is about a month old. Also while im driving in the dark I see my headlights and interior lights diming. Like there is power surging through the car. I think there is something thats causing the fuel pump to shut down. I dont know what though???
Jan 16, 2016 at 5:04 AM
HMAC300
  • 48,601 POSTS
try a different key first then check battery for condition including load test. most places do for free
Jan 16, 2016 at 6:43 AM
JAYSON360
  • 13 POSTS
I'll give it a shot. But the battery is only about a month old.
Jan 16, 2016 at 6:51 AM
HMAC300
  • 48,601 POSTS
even new batteries go bad. but the key may be worn and using security to shut the car down as well. also check fusiblelink going to alternator
Jan 16, 2016 at 7:05 AM
JAYSON360
  • 13 POSTS
10-4 thanks
Jan 16, 2016 at 7:07 AM
