Engine shut off while driving
100,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
VELLY HUBBARD
It will just shut off while driving after letting sit a few minutes start back up. I have changed fuel filter, control module and ignition coil pack. While test driving it shut off once, started back up. A belt broke, but was able to drive home. Do belts have anything to do with car shutting off? What are your thoughts?
Aug 7, 2018 at 6:08 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just a quick question. Have you load tested the battery and tested the alternator? I have attached the links for you. Hope this helps and thanks for using 2CarPros.
Danny-
Aug 7, 2018 at 11:35 AM
