Broken magnet in replacement coolant overflow tank
150,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
KIMBERLY WHYSPERS
broken magnet in replacement coolant overflow tank , will it still work?
Jul 26, 2020 at 3:16 AM
STEVE W.
  • 15,394 POSTS
The level sensor likely won't work unless the magnet is only cracked but still moving. If it is broken and not moving with the float then the level light will likely stay on and cause a code.
Jul 26, 2020 at 6:23 AM
