broken magnet in replacement coolant overflow tank , will it still work?
Jul 26, 2020 at 3:16 AM
STEVE W.
✓Experienced Mechanic
The level sensor likely won't work unless the magnet is only cracked but still moving. If it is broken and not moving with the float then the level light will likely stay on and cause a code.
