Can my truck crank up without the fuel tank pressure sensor?
Oct 6, 2022 at 12:35 AM
✓Experienced Mechanic
Yep, it will run without the fuel tank pressure sensor. if you want to replace it, here is how in the images below. Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Oct 6, 2022 at 4:58 AM
TAMMY COLE
MEMBER
1 POST
If it's not a v8 it's a v6 Ford F150.
Oct 10, 2022 at 5:09 AM
My bad, here is the location of the sensor. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
