vehicle shut off and now my key will not be released and it will not start
175,000 MILES
JENNIBERTRAND
Battery saver light traction control off and stabilization track then the vehicle shut off and now my key will not be released and it will not start.
Dec 16, 2019 at 5:03 AM
Good afternoon,
Sounds like your battery is dead. You need to charge the battery back to 12.6 volts and have the charging system checked.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
https://www.2carpros.com/articles/how-to-replace-an-alternator
Dec 16, 2019 at 5:24 AM
JENNIBERTRAND
If it was the battery wouldn't it start with a jump? Try to have somebody jump me nothing ended up happening. no lights no anything and their cables were super hot by the time they took them off.
Dec 16, 2019 at 6:23 AM
JENNIBERTRAND
About 20 minutes before the car shut off it's a battery saver mode and then I'm going down the road it starts beeping start saying no traction check stabilization track battery light was on and now my key won't be released.
Dec 16, 2019 at 6:24 AM
You to change the battery because charging a bad battery does not help. When you get a new battery, the key will come out.
Dec 16, 2019 at 6:27 AM
