Brembo brakes
2014 CADILLAC
20,000 MILES • 2.0L • 4 CYL • TURBO • AWD • AUTOMATIC
MTRANDYD237
Have a reoccurring problem with the brakes screeching when backing out of the garage in the morning or backing out of a parking spot at the end of the day.
Been to Cadillac service a couple of times, short temporary fixes is all the seem to be able to do.
Email the problem directly to Cadillac but they are not responding.
Any suggestions to stop the horrid screeching
Jan 14, 2016 at 12:49 PM
CAR-MAN145
  • 321 POSTS
You car try to have ceramic brake pads put on it.
Jan 14, 2016 at 4:55 PM
MTRANDYD237
The Brembo brake system is an upgraded braking system with ceramic brakes. From what I understand that is part of the problem.
Jan 14, 2016 at 10:44 PM
HMAC300
  • 48,601 POSTS
ceramic shouldn't make noise. I assume this is a V series, check to see if anything is stuck between shields and rotor like rust. that can do that. I am also assuming brakes are in good shape as well and rotors are not scored etc.
Jan 14, 2016 at 11:07 PM
