Make them lock up.
Then open the bleeder screw.
Did they release? (Maybe just one side locking up?)
If it released,
It is probably a faulty brake hose(s).
If you allowed old hoses to dangle with the weight of the calipers this may have accelerated the failure.
What is happening in this possibility is the hose(s) have deteriorated internally, it is allowing fluid to push on through, it sort of "check valves" and will not let the fluid back up/ retract as it should when the pedal is released.
This situation can occur without messing with the brakes, just one of those things!
Return with news!
The Medic
SPONSORED LINKS
Wednesday, August 9th, 2017 AT 4:44 PM
