breaklights
150,000 MILES
KEVIN DICK
The brake lights are not working, but the third brake light in the rear window does work. All the fuses seem to be good and with the third brake light working. I do not think it could be the switch on the brake pedal. What else could it be?
Jun 22, 2016 at 1:01 PM
SATURNTECH9
  • 30,869 POSTS
It could still be the switch most of the time there are power feeds coming out of the switch for left right and high mount brake lights. Do you have a test light to do some testing?
Jun 22, 2016 at 4:02 PM
KEVIN DICK
Yes I have a test light somewhere or at least can go pick one out. What exactly do I want to put the test light on on the switch behind the pedal or at the bulbs or just all around and just keep watching where I have power? I have definitely never been mistaken for an electrician.
Jun 23, 2016 at 4:09 AM
  • 110,248 POSTS
If the brake lights are the same as the signal bulbs, a bad turn-signal switch can cause this type of problem. A bad signal switch will still allow the third light to work. With this system, the turn signals and brakes use the same circuit. Power is run through the signal switch to the brake lights. The turn signal switch, when used, cancels the brake light signal on the side selected otherwise the light would not flash. Also, an open circuit to the lower tail lights can be the problem.
Jun 23, 2016 at 12:31 PM
SATURNTECH9
  • 30,869 POSTS
When stepping on the brake your looking for power on the dark green wire and the yellow wire coming out of the turn signals switch?
Jun 23, 2016 at 1:18 PM
