Braking issue
141,000 MILES • 2WD • AUTOMATIC
PANZU
Hello, thank you for helping. Pressing the brake I heard a noise and it seems the pedal is pushing back my foot and the car seems to roll without brake for a few seconds. All brake pads are new front and back, both front rotors are new and also both front wheel bearing are new.
Mar 23, 2019 at 1:09 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Based on your description, it sounds like the ABS is actuating when you apply the brakes. Most times, this is caused by a faulty wheel speed sensor. With that, I suggest checking them first. Here is a link that shows how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
You will need to use a volt meter to perform the test. Here are a couple links that you may find helpful:
Mar 23, 2019 at 3:10 PM
PANZU
Thank you so much JacobandNickolas. I had my friend check the sensor as per your recommendation. They were not defective but not align properly through the dust cover metal plate hole (hope this is the right name for this part). He cleaned them and aligned them properly and I went for a successful test drive.
Apr 1, 2019 at 11:06 AM
  • 110,248 POSTS
Welcome back:
You are very welcome. The dust and dirt eliminated the signal. Thus, that is what was happening. The ABS was actuating. I'm really glad you got it taken care of.
Let us know if you have questions in the future.
Take care or yourself,
Apr 1, 2019 at 11:46 AM
