No brake pedal?
2000 MERCURY MOUNTAINEER
150,000 MILES • 5.0L • V8 • 2WD
JASON LEWIS
Brakes with slack replace brake booster and master cylinder bled the lines still have no brake pedal cannot figure out why.
Jan 6, 2023 at 1:16 AM
  • 110,240 POSTS
Are you certain there are no leaks? Did you check the pushrod adjustment? See pics 1 and 2 below. Also, when you bleed the brakes, are you starting at the right rear, left rear, right front, and left front order? Are you getting a good stream of fluid?
Let me know. Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Jan 6, 2023 at 2:57 PM
