Brake pedal locked and warning light on dash?
60,000 MILES • 1.4L • 2WD • MANUAL
AIDMILLER
Car brake pedal locked when coming to a junction then the dash lit up with battery light oil and another came on had to roll to side of the road, then turned engine off. Then my partner arrived, started it and drove it home and it seemed fine. I was thinking maybe the weather, with being the hottest day on record. I have only had the car for four days.
Jul 19, 2022 at 2:00 AM
BORIS K
  • 836 POSTS
With "brake pedal locked up" do you mean that the pedal became hard to press or did the brakes lock up when stopping?
When warning lights came on it would be best to first conduct a CAN-scan to see if any relevant fault codes are stored.
How to conduct a scan:
Once the scan has been done, please post the fault codes on here so that we can evaluate and try to assist you.
Cheers, Boris
Jul 19, 2022 at 2:05 AM
AIDMILLER
Sorry the brake pedal went stiff.
Jul 19, 2022 at 2:11 AM
BORIS K
  • 836 POSTS
Is your car petrol or diesel?
Your model was released in both versions.
Either model a hard brake pedal is caused by a lack of vacuum to the brake booster.
See video below.
https://youtu.be/l8CzDWmve_M
And how a brake booster works.
https://youtu.be/hvtafFiGD78
You mentioned that you had warning lights come on when this happened.
Therefore, there should be fault codes stored in the relevant electronic control modules.
As previously suggested, please carry out a CAN scan next using a suitable diagnostic tool.
Cheers, Boris
Jul 19, 2022 at 5:46 PM
