break lights out at same time
140,000 MILES • 4 CYL • AUTOMATIC
BARBARANN141
What do I do? Where is the fuse? All other lights are working.
Thank you. If the fuse is good and the bulbs are good, what then?
Apr 29, 2015 at 9:47 AM
  • 110,251 POSTS
Fuses are under the dash in the fuse box. If good and the lights are good, check the brake light switch on the top of the brake pedal to make sure it is getting power and properly adjusted.
Apr 29, 2015 at 11:48 AM
THIS IS MIKE
  • 686 POSTS
Barbarann141
April 29, 2015.
Thank you, I will let you know. I I'm seventy years old and need my car for Church and the Doctor and for helping to get groceries for those without a car that live in this senior residence.
God bless you for helping others.
Next time I will help with a donation but it might be five dollars because I only get a thousand and twelve a month.
Apr 30, 2015 at 2:54 AM
