Sudden loss of brakes and brake fluid pouring out of front driver wheel area
200,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MONIILOVE31
My SUV all of a sudden has next to no brakes. Had no issues before I changed brakes about two months ago. So suddenly lose all brakes then at the same time brake fluid
almost pouring out front driver tire. What is wrong with my truck?
K
Sep 6, 2018 at 6:56 AM
  • 31,937 POSTS
It sounds as if you have burst a flexible brake hose. The best way to check is to wash down all the leaking brake fluid and let it dry, then top up the master cylinder and watch the hose while someone pumps the brakes. If the hose has failed, you will see the fluid leaking. If this is the case, do not drive the car as you will have no brakes after a few applications at best, repair on site or tow to the nearest workshop for the repair. If you want to do the repair please let me know and I will talk you through the process, you will need some understanding of what you need to do and also access to tools for the job.
Sep 6, 2018 at 10:02 AM
