brakes are not working properly it is hard to stop and the warning light is on
85,000 MILES
FALLATCO
There are many problems:
1. the vehicle hard to stop.
2. all warning lights is on.
3. I heard a beep beep alarm constantly.
The check engine light is off.
Help me please!
Dec 28, 2016 at 3:36 PM
SATURNTECH9
  • 30,869 POSTS
If you have an ABS light on traction light, etc then you need to have it with a scan tool that can read ABS traction control etc codes.Most diyer scan tools cannot read them.
That is your starting point then you might even need a advanced scan tool that can read live ABS data and be able to activate different parts of the ABS.
Also, write down the exact code numbers not code descriptions that way you can post them on this question.
Dec 28, 2016 at 10:11 PM
