brass float on sending unit
180 MILES
REVCARLA
I can't locate a replacement part for the brass float that attaches to the fuel pump in the Saturn. All the after market fuel pumps tell you to use the old sending unit float. The sending unit itself works fine but the float has gas in it and therefore does not work properly. Any suggestions of another vehicle's float that can be used without retrofits.
Apr 18, 2013 at 5:16 AM
SATURNTECH9
  • 30,869 POSTS
You would have to replace the sending unit ac delco part number 21015335 rockauto.com has them and I have a 5 percent discount code if interested.
Apr 18, 2013 at 5:23 AM
