Braking System
2006 HYUNDAI H100
67,700 MILES
WITMAN
I replaced the brake master cylinder on the h100 hyundai, however i still have to pump the brake paddle to make the vehicle stop. i have to step four to five times for the brakes to respond. what could be the problem.
Regards
Witman
May 1, 2013 at 11:02 PM
KHLOW2008
  • 41,814 POSTS
Was the system bled of air?
Is the brake fluid level correct and did you check for leakages?
Have you checked the calipers for binding and if rar are drum, check the slave cylinders for seizure.
If vehicle is equipped with ABS, it could be the modulator tthat has a problem.
May 1, 2013 at 11:42 PM
