Brakes do not work
180,000 MILES • V6 • 4WD • AUTOMATIC
LOOK4THESTARS518
My friend's vehicle's brakes are not working. they have replaced the brakes pads already. the brake fluid is not empty. the calipers are working properly, the rotors are fine. so we don't know what would be the problem.
Jan 26, 2019 at 6:05 AM
  • 110,248 POSTS
If the brake pedal goes to the floor, then the master cylinder is bad. I am basing that on the fact there are no leaks and the master cylinder still has fluid. If that isn't happening, let me know. However, if the brakes aren't working at all, there really isn't another cause. Individual components can go bad, but that won't cause all brakes to fail.
Here are the directions for replacing a master cylinder as well as an explanation of what can cause the brake pedal to go to the floor:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Jan 26, 2019 at 1:45 PM
