Brakes wont release after car is running
125,000 MILES • 2.0L • 4 CYL • 2WD
RAY HUNT
Replaced brakes then brakes started to drag, then they would not release disconnected the booster brakes release. is the booster bad or is there something else I need?
Oct 29, 2016 at 12:09 AM
JIS001
  • 3,412 POSTS
Pull the master cylinder out and check for leaks and to see if the booster is sucking in brake fluid. If it is then the master cylinder and booster will need replacing.
Oct 29, 2016 at 2:50 AM
