Brakes will not pump up
157,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
TLBECK
  • 9 POSTS
Everything was fine until the chirping noise. Quickly found out it was the Accumulator.
Followed instructions exactly like they said. Couldnt get the brakes to pump up. So went ahead and replaced the Accumulator and bleed the lines.
Started engine, listened to the pump come on and about 25 seconds later it shut off. Turned ignition off and brakes will not pump up. No brakes at all.
What do we check now?
Jul 18, 2019 at 11:09 AM
  • 55,865 POSTS
Its sounds like you got a bad (flat) accumulator. Why did you replace it? The pump shuts off because it has ran its maximum time limit. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Jul 21, 2019 at 8:01 AM
TLBECK
  • 9 POSTS
Well it may take me a few days. But I'll see what I can do. I have the shingles and not doing much right now.
Thank you
Jul 21, 2019 at 11:35 AM
TLBECK
  • 9 POSTS
Replaced the Accumulator because of the chirping noises under the dash.
Jul 21, 2019 at 11:37 AM
  • 55,865 POSTS
Okay, good luck on the shingles and let me know what happens.
Jul 22, 2019 at 3:29 AM
TLBECK
  • 9 POSTS
Will do.
Jul 22, 2019 at 9:28 AM
TLBECK
  • 9 POSTS
Here is a video. Over the shingles, woohoo.
Aug 24, 2019 at 7:49 AM
TLBECK
  • 9 POSTS
Ken is who ask for a video to listen and see the brake system.
We returned the defective accumulator and yesterday received the replacement. It was installed yesterday and the brakes still will not pump up.
Seems like everything is working but pumping the brakes for pressure.
Maybe the attached video will give you an idea of what we need to do. Brake lines have been bled. We even opened the calipers on the rear brakes and let them drip for 15 mins and then did the same on the front, keeping the reservoir full at all times.
Help if you can. Is there a code that needs to be changed or maybe a check valve or something we missed?
Aug 24, 2019 at 11:06 AM (Merged)
  • 55,865 POSTS
Does this car have ABS? if so you will need a scan tool to open the ABS valve while bleeding to remove the air from the system. This guide should help:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Aug 26, 2019 at 5:22 AM
TLBECK
  • 9 POSTS
Thank you will show this to my brother tomorrow. And see what we can do. Will be in touch.
Aug 26, 2019 at 2:23 PM
  • 55,865 POSTS
Sounds good, please let us know.
Aug 27, 2019 at 4:11 AM
TLBECK
  • 9 POSTS
Will do, we have to find a scan thing.
Aug 27, 2019 at 4:47 AM
TLBECK
  • 9 POSTS
Wow! does it have to be a MUT III ? If so we are just out of luck. No way could be afford one of those. Any other scan tool that is way way cheaper?
Aug 28, 2019 at 2:53 AM
  • 55,865 POSTS
