brake master cylinder replacement
180,000 MILES • 5.4L • 6 CYL • 2WD • MANUAL
ALLEN FITTS
I changed out my brake pads, bled the brake lines, and my brake pedal is still going to the floor. I have checked fluid levels, and are all full. I have no leaks at any given point.
Mar 29, 2020 at 3:32 AM
At this point the issue is most likely the master cylinder leaking internally.
Also it could a brake line issue that is swelling when you press the pedal. However, this will normally cause a soft pedal and not going to the floor. So I would think the master cylinder is leaking internally. Here are the master cylinder installation instruction you have requested. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/WDxvEQrMkBg
and
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
If you take the lines off and cap the outlets of the master cylinder then press the pedal if it still goes to the floor then you know if it is leaking internally because you have eliminated the rest of the braking system.
Let me know if you have questions. Thanks
Apr 6, 2021 at 5:21 AM
