Brake pedal goes to the floor
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHAN777
Brakes are touching the floor even after replacing master cylinder two times. I have to go to mechanic every few weeks to fix it and they’ll fix something in the rear wheel. I’ve shown to many mechanics but they couldn’t figure out what is wrong.
May 29, 2019 at 3:11 PM
Good morning,
Do you have the receipts for the work done so I can see what they did? Can you upload it here to the site?
It could be either a leak back there or air getting into the system for some reason.
I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 5, 2021 at 2:50 AM
