Brakes to the floor
128,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
JRHERM5115
Replaced both front calipers, rotors and brake pads. Had brakes before the work was done, now we have none. The pedal just goes to the floor.
All brakes were bled so we are unsure of what the problem actually is.
Hoping you can help!
Sep 7, 2018 at 6:58 AM
Good afternoon.
It could be a failed master cylinder not building pressure internally.
Did you get a good fluid flow when you bled the brakes?
Did you bleed all four wheels?
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Sep 7, 2018 at 7:34 AM
JRHERM5115
Yes, we did all four and had solid fluid flow, no air.
Sep 7, 2018 at 7:39 AM
Then it sounds like you have a failed master cylinder.
Before going there, if there is air in the system, you need to bleed the ABS. That can only be done with a scan tool.
Procedure below.
Automated Bleed Procedure
Notice: The Auto Bleed Procedure may be terminated at any time during the process by pressing the EXIT button. No further Scan Tool prompts pertaining to the Auto Bleed procedure will be given. After exiting the bleed procedure, relieve bleed pressure and disconnect bleed equipment per manufacturers instructions. Failure to properly relieve pressure may result in spilled brake fluid causing damage to components and painted surfaces.
1. Raise and support the vehicle.
2. Remove all 4 tire and wheel assemblies.
3. Inspect the brake system for leaks and visual damage. Repair or replace components as needed.
4. Lower the vehicle.
5. Inspect the battery state of charge.
6. Install a scan tool.
7. Turn the ignition ON, with the engine OFF.
8. With the scan tool, establish communications with the ABS system. Select Special Functions. Select Automated Bleed from the Special Functions menu.
9. Raise and support the vehicle.
10. Following the directions given on the scan tool, pressure bleed the base brake system.
11. Follow the scan tool directions until the desired brake pedal height is achieved.
12. If the bleed procedure is aborted, a malfunction exists. Perform the following steps before resuming the bleed procedure:
* If a DTC is detected, refer to Diagnostic Trouble Code (DTC) List - Vehicle , and diagnose the appropriate DTC.
* If the brake pedal feels spongy, perform the conventional brake bleed procedure again.
13. When the desired pedal height is achieved, press the brake pedal to inspect for firmness.
14. Lower the vehicle.
15. Remove the scan tool.
16. Install the tire and wheel assemblies.
17. Inspect the brake fluid level.
18. Road test the vehicle while inspecting that the pedal remains high and firm.
Sep 7, 2018 at 7:56 AM
JRHERM5115
Okay great! I appreciate your help very much. We will be using the steps you have provided us and hopefully getting to the bottom of things.
Thanks so much for your time!
Sep 7, 2018 at 8:06 AM
You are welcome. Glad to help.
Sep 7, 2018 at 8:29 AM
