Brakes to floor
185,194 MILES • 4 CYL • 2WD • AUTOMATIC
CANRAVENS
Brakes go to floor. Car stops but brakes go to floor. So far, I have checked brakes (good), checked brake fluid (good) , changed master cylinder, bled brakes. Didn't work so changed two rear wheel cylinders. Rebled brakes. Still goes to floor.
Apr 3, 2019 at 10:13 AM
Good evening,
Did you pressure bleed the system or just have someone push the pedal? It sounds like you have air trapped in the lines.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 29, 2021 at 3:51 AM
