After driving for about 10 minutes something pressurizes the brakes in the front at least?
280,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
CHRIS JOHNSON4
They are partially locking up and get extremely hot. After the van cools down the pressure is relieved. Both sides affected. I have changed calipers, rotors, pads, soft brake lines, master cylinder, booster, ABS module including the electronics and valve body. Had the brake system flushed. The only thing that had any effect was the booster change made it way worse I assume because now the brakes work well again (mush less pressure needed to stop). Booster check valve holds vacuum so don't think that it. This started two years ago. At first it was only occasionally when driving fast like on the interstate and it was hot out. it went away in the winter. But it has gotten progressively worse until now it happens all the time after even a short drive at moderate speed. Have taken it to three shops no one can figure it out.
Aug 3, 2022 at 11:45 PM
CARADIODOC
  • 34,415 POSTS
The rubber flex hoses were the best suspect for this problem. Next would have been brake fluid contaminated with a petroleum product. The only proper repair for that is to remove every part that contains rubber parts that contact the brake fluid, flush and dry the steel lines, then install new parts. Simply flushing the old fluid out isn't sufficient. The contamination will leach out of rubber parts that weren't replaced and recontaminate the new fluid.
Your dandy description of the symptoms points to this not being caused by contaminated fluid. The next place to look is at the new booster and push rod. Import models commonly have an adjustable push rod as shown by the blue arrow below. The starting point is to adjust it to match the one you're removing unless the instruction sheet tells you it was already adjusted during reassembly. When the brake system is working properly, that adjustment doesn't change on its own or need to be checked. This would be the place to look if the locking problem only started right after the new booster was installed.
The better suspect now is the brake light switch is out of adjustment and is holding the brake pedal down a little. It only takes an inch of pedal travel to run the rubber lip seals in the master cylinder past the fluid return ports. That blocks brake fluid from returning to the reservoir. The dragging brakes heat up, then that heat migrates into the brake fluid, causing it to expand. Since it can't flow into the reservoir, it applies the brakes even harder. The cold winter weather might reduce how bad the symptoms are.
A good clue to verifying this is to park on a slight grade when the problem is occurring, place a block about a foot downhill of one tire, shift to neutral, then loosen the nits holding the master cylinder to the booster. Slide the master cylinder forward about 1/8". If that lets the brakes release, the cause is either the push rod in front of the booster, or the push rod going into it from the brake pedal. You can also try pulling up on the brake pedal with your foot. If the brakes release when you do that, the brake light switch is holding the pedal down a little.
Let me know what you find, then we'll figure out if we need to look further.
Aug 4, 2022 at 10:15 AM
CHRIS JOHNSON4
Thanks for that very thoughtful reply. I tried disconnecting the brake pedal. that made no difference. I will try loosening the master cylinder bolts when i get a chance, that's a good idea. I'm wondering if there is any way (even though the pedal is firm and i had the lines flushed at a shop) that there could be air in the line that is heating up and causing this issue. This issue started randomly, not after any kind of work was done.
Aug 9, 2022 at 12:06 AM
CARADIODOC
  • 34,415 POSTS
Air in the hydraulic system causes the opposite problem. The brake pedal would be low and mushy. Air can compress, so a blockage in a line would allow heating brake fluid to expand rather than apply the brakes harder.
Regardless of the cause, if brake fluid warms up, it is going to expand, then it has to be able to flow back up into the reservoir. Something is preventing that from occurring. That causes expanding fluid to apply the brakes harder and harder. What we need to do now is get the problem to occur, then open the hydraulic system in various places to see what allows the locked brakes to release. If you loosen the soft metal line nuts at the master cylinder and the brakes release, that proves the master cylinder and its adjustments are what we need to look at. The expanded fluid was allowed to release through the loosened lines.
If the brakes still don't release with the lines loosened at the master cylinder, the next easiest place is to open the bleeder screws on the calipers. While much less likely, if they still don't release, suspect a problem with the caliper mounts and / or slides. Look for grooves worn in the mounting surfaces that the caliper is catching on. Siennas use replaceable stainless steel shims with anti-rattle clips. Those can cause misery when trying to install new pads. On one I worked on recently, one side went together extremely easily. On the other side I was tempted to throw those inserts away. I had to fight for quite a while to convince the parts to go together. If one of those was left off during the last brake job, the caliper might be sticking. The clue here is cooling down usually doesn't affect how the problem occurs or is resolved.
You said the rubber flex hoses were already replaced so I kind of skipped over that. This is still a good suspect if the brakes release when you open the bleeder screw on the caliper. Two defects can occur. One has to do with any model that uses a metal bracket crimped around the middle of the hose, as shown by my blue arrow. Rust can develop inside that crimp and constrict the hose. You can force brake fluid through that restriction with your foot, but the fluid can't release freely to return to the caliper. This is where its being trapped keeps the brakes dragging which builds more heat. That heat migrates into the fluid causing it to expand and apply the brake even harder.
The second defect occurs when the caliper is allowed to fall or hang freely on the hose while a brake job is being performed. That can tear the inner liner causing it to form a one-way check valve. The passage through the hose isn't very big, so it doesn't take much to block it. The best place to verify this is to loosen the soft metal line nut where the steel line connects to the rubber hose. If that is rusted tight, the next best place is where that steel line comes out of the anti-lock brake hydraulic controller.
Rubber brake line problems affect only that one brake. While it is possible to have two individual hose problems develop at nearly the same time, the better approach with multiple locking brakes is to look at what they have in common. That's why I started with the master cylinder "input" side, meaning the pedal, push rod, and booster.
See how far you get with this information, then we'll continue on.
Aug 9, 2022 at 5:35 AM
CHRIS JOHNSON4
thank you again. i will proceed to check as you suggest. i have replaced the soft brake lines twice on both sides. that had no effect so ill focus on the master cylinder/booster and try to see where the pressure is relieved.
Aug 10, 2022 at 3:59 AM
