Brakes Pedal Pushing Back - Intermittent
167,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
SOUTHDAKOTARON
The brakes work normal, however, occasionally, at least 1-2 times a day, during the braking process, I feel the Brake Pedal pushing back on my foot and feel a nudge out of the rear brakes. The brake pads have been replaced, brakes bled and checked over. Am I dealing with a Master Cylinder problem?
Kind Regards
Ron Clark
Sep 28, 2014 at 3:24 AM
HMAC300
  • 48,601 POSTS
have a pro scan for an abs problem it still may be a bleed issue which a pro may have to do to open valves on abs so it gets bled properly.
Sep 28, 2014 at 6:23 AM
SOUTHDAKOTARON
Thank you, I appreciate the information.
Kind Regards
Ron Clark
Sep 28, 2014 at 10:43 PM
