Brake pedal goes to floor there is fluid in reservoir
70,000 MILES • AUTOMATIC
46&TOOL
Brake pedal goes to floor. There is fluid in reservoir, but fluid is leaking from under truck. Not from a tire or behind one but the middle of the truck. Like the center of the truck from front to back and side to side. Not near an axle.
I am assuming it is the master cylinder but am only guessing.
If it is, is it an expensive fix?
Jul 16, 2017 at 5:41 AM
CARADIODOC
  • 34,414 POSTS
The master cylinder is in front of the driver's feet, just to the right of the left front wheel. When the leaking is in the middle of the vehicle, it is almost always from a rusted steel line going to one of the rear wheels. On some vehicles it is easier to unbolt the line at each end, then just replace it with new pieces of pre-manufactured line. Those are pretty inexpensive. On some vehicles it is almost impossible to remove the complete line. For those, we look for two rust-free areas where we can cut out the rusted section, install fittings, make double-flares, and then install a replacement line just in that one section.
Be aware that given the age of the vehicle, pushing the brake pedal all the way to the floor likely damaged the master cylinder from running the pistons and lip seals over the crud and corrosion that build up in the unused areas. You may need to replace it if you cannot get a solid pedal after the line is replaced and bled.
Jul 16, 2017 at 12:32 PM
