Brakes occasionally lock up at parking lot speeds
108,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
ROBERK26
  • 5 POSTS
I tend to do a lot of driving on slippery and/or icy roads, and as such my braking habits are always to start applying brakes early and slowly increase pressure on the pedal as I slow down to prevent locking and skidding. I try to keep ahead of the ABS if I can help it, mostly because i drive older vehicles where the ABS system no longer works as well as it should.
That being said, occasionally as I leave the parking lot and come to a stop before entering the road, I begin applying brake pressure and it feels like the brake system just dumps full pressure into the lines as soon as I move the brake pedal. This will also happen as I slow to a stop at the intersection just down the street. Braking action will be fine down to roughly 5 mph, then it feels like it just dumps full pressure to the brakes. I can hear the ABS trying to unlock the wheels, and I feel movement in the pedal, but the 26 year old system just doesn't work right anymore. I manually pump the brakes when this happens, but it is like I am operating a switch instead of a pump--either full brake pressure, or nothing, instead of being able to increase or decrease pressure.
Like I said, this only happens occasionally. When I do have this issue, 90% of the time it goes away after 10-15 minutes of driving around.
Mar 14, 2020 at 6:58 AM
Good afternoon,
The ABS applies the brakes. What do you mean you hear it releasing?
Did you have the codes checked for any faults in the ABS system?
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
When was the last time you changed the brake fluid? Dirty brake fluid will cause all kinds of application issues.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Mar 14, 2020 at 8:41 AM
ROBERK26
  • 5 POSTS
Thanks for the reply, Roy
This truck hasn't given me any warning lights so far. I did want to run a scan to see if there were any hidden codes (or a burnt out warning light), but the GM OBD1 scanner has been on back order from my local parts store.
Sorry, I didn't describe that very well. When the ABS system engages and operates normally, I can hear some noise up front, which I assumed was just normal from the ABS module in a situation where it senses a lock-up situation. The same sound occurs when I have the issue where the brakes lock up, but the ABS system can't seem to unlock the brakes until I pull my foot off the pedal. I manually pump the brakes out of instinct, and like I said it feels like I either have max pressure, or no pressure when this issue arises.
As for changing the brake fluid, I have not done that since I purchased the vehicle 6 months ago. All the fluids appeared to be topped off and fresh when I bought the truck. I know the radiator/cooling system got flushed, and the oil changed just before I bought the truck. The brake fluid in the reservoir looks fresh, but that doesn't mean it got flushed. I can tell the brake system is bled. I will try flushing the brake system a little later this spring when it warms up a little and the road back to the hangar where I keep my tools is a little more passable. I wasn't thinking far enough ahead and I only grabbed my aircraft repair tools, and left pretty much all of my metric stuff back in the hangar.
Bob
Mar 14, 2020 at 9:30 AM
Thanks.
I would have the codes checked. it sounds like it could be either a sensor or the brake motor for the ABS.
Mar 14, 2020 at 9:36 AM
