brakes make noise
2008 ALL OTHER MAKES ALL OTHER MODELS
RAGINGCAMARO
My car is starting to make a shimmy sound when I hit the brakes. How long do brake pads usually last?
Apr 11, 2013 at 4:55 AM
RAGINGCAMARO
I meant to say how many miles do they last?
Apr 11, 2013 at 5:04 AM
CARADIODOC
  • 34,379 POSTS
Brake pad life is not measured in miles. There are WAY too many variables. I've seen pads last 7,000 miles on brand new Ford trucks and well over 100,000 miles on the my Grand Caravan. Neither is normal nor abnormal.
A "shimmy" is a vibration, not a noise. If you have a vibration suspect warped brake rotors. If you have a sound it could be caused by something as simple as rust buildup on the rotors or as serious as worn pads and the backing plates are starting to grind on the rotors. A brake system inspection is probably in order.
Apr 11, 2013 at 6:12 AM
