Brakes locking up
130,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
AL MILTON ARGOTE JR.
After driving car about fifteen minutes brakes lock up. I have replaced ABS pump. Two front calipers. And master cylinder still locks up. What strange is that it locks up even without driving it after car warms up for say fifteen minutes while parked I tried moving it and it was locked up already. I shut off let car cool down and then it unlocks.
May 19, 2019 at 9:42 PM
  • 55,673 POSTS
It sounds like the master cylinder push rod needs to be adjusted inward. To confirm when the brakes are lock please loosen the master cylinder mounting bolts allowing the master to slide forward slightly, if the brake unlock remove the master and wind the push rod adjustment inward. Please let me know what happens.
May 21, 2019 at 7:19 AM
Thank you very much. it worked just like you said.
May 21, 2019 at 1:31 PM
  • 55,673 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
May 23, 2019 at 4:10 AM
