Brakes groaning in heavy traffic
36,567 MILES • 5.7L • V8 • 2WD • AUTOMATIC
HEYMAN764
  • 24 POSTS
Hello, so today I got caught in very heavy severe traffic. Car ran great but after an hour, every time I hit the brakes they started making a grinding/groaning sound that could be felt through the pedal. Once I got out of traffic, the sound went away and the brakes went back to normal, it only did it when the brakes were applied, sound went away when I released the brakes. The car has factory power brakes, disc in front, drums in rear, sound was coming from front. What could have caused this?
Thanks
Aug 23, 2018 at 2:40 AM
  • 110,248 POSTS
Often times the pads themselves will make a strange noise under extreme heat. I would recommend checking the front pads to make sure there is not an issue, but chances are it was due to heat.
Here is a link which shows how brake pads are replaced. You can use the directions for inspecting the ones on the vehicle.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Aug 24, 2018 at 11:50 AM
  • 55,676 POSTS
It sounds like the front pads are metal to metal. Here is a guide to help you get the pads and rotors replaced:
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Aug 24, 2018 at 11:51 AM
HEYMAN764
  • 24 POSTS
The brake pads have about 75% life left in them. I took a good look at both sides and did not see anything out of the ordinary. I went for a good drive and the brakes did not make any noise and were smooth as can be. I am going to go ahead and say they probably just got hot from the stop and go.
Thanks
Aug 24, 2018 at 10:52 PM
  • 55,676 POSTS
I could be can I ask what kinds of pads? I would use a semi metallic they work the best for noise issues. Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Aug 25, 2018 at 6:12 AM
  • 110,248 POSTS
Ken is exactly right with the type of pads. Also, often times you can get a brake squeal if the rotors and pads are glazed. Let us know if you have other questions.
Have a good weekend.
Aug 25, 2018 at 10:55 AM
