This started my problem before I replaced these things that probably needed changing.
Hydro boost, all calipers, rotors, pads, and hoses.
I have not replaced the master cylinder as the fluid is clean and there are no leaks, etc. And I did not replace the brake pedal switch.
Only the front brakes are locking down within a short driving time. At least the rear seem to be at a normal operating temperature.
I have the "stabilizing" light on, so could the ABS be causing this?
Mar 14, 2021 at 1:28 AM
