Brakes going out
HCASHEW
I have a 1997 Dodge Stratus and all the brake pressure is flattening out. Brakes going out. Can I change fluid on my own to keep steady until I have a mechanic bleed and change them properly?
I cant raise the dough to have the local mechanic until payday Friday.
In the meantime. can I extract and add new fluid to get me to and from work? Would it make a difference?
THX
Oct 8, 2013 at 5:43 AM
  • 110,244 POSTS
Brake fluid doesn't wear out. It gets dirty. However, rarely does it need changed. So, I don't think that will help. Can you explain what is happening with the brakes so I can direct you?
Oct 8, 2013 at 10:15 AM
