Brakes creak
195,650 MILES • 3.0L • V6 • 2WD • AUTOMATIC
LUBEJOB
  • 8 POSTS
when outside temperature over 65-70F my brakes creak when I press on brake pedal and a sound coming from outside passenger front wheel. I have checked my brakes everything looks normal, what can it be? Any suggestions would be appreciated. thank you
Jun 8, 2019 at 3:16 PM
JIS001
  • 3,412 POSTS
Can you record the sound and post it on hear so we can hear it?
Jun 8, 2019 at 3:26 PM
LUBEJOB
  • 8 POSTS
sure, i will do that.
Jun 8, 2019 at 3:28 PM
JIS001
  • 3,412 POSTS
Thank you. That would help a lot.
Jun 8, 2019 at 3:51 PM
LUBEJOB
  • 8 POSTS
I'm trying to upload 27sec audio file and it says "Filetype not allowed"
Jun 8, 2019 at 4:18 PM
  • 55,694 POSTS
We take all popular file types, what phone are you using?
Jun 11, 2019 at 3:10 AM
LUBEJOB
  • 8 POSTS
iPhone 6.
Jun 12, 2019 at 9:41 AM
  • 55,694 POSTS
hmm, that might be the problem. I will ask our programmer, sorry for the inconvenience.
Jun 14, 2019 at 4:02 AM
LUBEJOB
  • 8 POSTS
No worries at all, I will figure out sooner or later how to upload, thank you for your help!
Jun 14, 2019 at 11:15 AM
LUBEJOB
  • 8 POSTS
Okay!!! I finally got it, this is what it sounds like when I step on & release brakes
Jun 14, 2019 at 11:43 AM
JIS001
  • 3,412 POSTS
That is a normal sound when your just barely moving. Majority of vehicles produce that sound. If the linings look good and rotors are within specification you should be good.
Jun 14, 2019 at 12:01 PM
LUBEJOB
  • 8 POSTS
Okay, thank you. but the car is not moving, it happens just from pressing and releasing brake pedal at complete stop. also I have owned this car for the last 14 years and it just started about 7-8 months ago.
Jun 14, 2019 at 12:55 PM
JIS001
  • 3,412 POSTS
Okay, try to clean the anti rattle Clips or replace them. Clean the backing surface of the brake pads in the back and contact points and lube them. Remove the slide pins and using an Emery cloth clean the pins and lube them to see if that will minimize the sound.
Here is a quick YouTube link to see where to grease the pads. Let us know if that helps reduce or eliminate the sound.
Watch "How to grease brake pads where to apply brake grease" on YouTube:
https://youtu.be/ow60E4ufW8U
Jun 14, 2019 at 2:03 PM
LUBEJOB
  • 8 POSTS
Alright, thank you so much I will definitely try this.
Jun 15, 2019 at 9:00 AM
JIS001
  • 3,412 POSTS
Your welcome. Let us know if it helps.
Jun 15, 2019 at 2:18 PM
