grinding noise in the rear passenger side
2000 BUICK LESABRE
160,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ILOVEJESUS72
I was wondering if it was perhaps the piston is stuck and pushing against my brake pads and not easing back in after letting off the brakes. Also when I apply my brakes it wants to ease to the left and my steering wheel is aimed a little to the left. Was wondering if this brake problem may be why it's steering left, and not necessarily an alignment issue.
Dec 13, 2020 at 10:56 AM
  • 110,194 POSTS
If you are hearing a grinding noise, chances are the brake pads are worn out on that side. However, there are other things that can do that also. What I recommend is inspecting them. If they are bad, here are directions for replacement. The attached pics will correlate with the directions.
_______________________________
2000 Buick LeSabre V6-3.8L VIN K
Brake Pads Replacement - Rear
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Brake Pads Replacement - Rear
BRAKE PADS REPLACEMENT - REAR
Removal Procedure
pic 1
1. Remove two-thirds of the brake fluid from the master cylinder.
2. Raise the vehicle and suitably support. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
Important: Do not use a screwdriver or pry bar to compress the caliper piston into the caliper. Any damage to the piston boot could cause corrosive elements to enter the piston sealing area and lead to the piston seizing in the caliper bore.
Important: Do not exceed more than 1 mm of piston travel. Damage to the internal adjusting mechanism may result.
4. Using a large C clamp compress the caliper piston into the caliper bore to gain enough clearance to allow the caliper to pivot off the caliper bracket. Compress the piston until resistance is felt, but no more than 1 mm of piston travel.
5. Disconnect the park brake cable bracket (2) from the brake caliper (1).
6. Remove the park brake cable from the cable ]ever.
pic 2
7. Remove the bottom caliper slide pin.
8. Pivot the caliper body (6) upward.
9. Remove the inboard (2) and outboard (3) pads from the anchor bracket (5).
10. Remove and inspect the pad retainers (1).
Installation Procedure
Important: Inspect the caliper bolt suspension boots for cuts, tears, or deterioration. If damaged, replace the pin boots. Inspect the caliper pin bolts for damage or corrosion. Replace if damaged or corroded. Do not attempt to clean away corrosion. Corrosion is typically caused by damaged pin boots. Inspect the piston boot for deterioration, repair or replace the caliper if damaged. Refer to Brake Caliper Overhaul Rear or Brake Caliper Replacement (Rear).
pic 3
1. Retract the caliper piston (2) into the caliper bore. Use a spanner type wrench to turn the piston (2) clockwise until it bottoms out fully in the caliper.
2. Align the cutouts in the caliper piston to the alignment pins on the back of the brake pad.
pic 4
3. Install the brake pad retainers (1) into the caliper anchor bracket (5).
4. Install the inboard (2) and outboard (3) brake pads into the caliper anchor bracket.
pic 5
Important: The caliper piston boot must lay flat. Make sure convolutions are tucked into place.
5. Use a small plastic or wooden tool (1) to lift the inner edge of the boot (2) next to the piston, and press out any trapped air.
6. Pivot the caliper down over the brake pads and into the anchor bracket.
pic 6
Notice: Refer to Fastener Notice in Service Precautions.
7. Insert the lower caliper slide pin.
^ Tighten the caliper slide pin to 27 Nm (20 ft. lbs.).
8. Install the park brake cable bracket (2) to the brake caliper (1).
9. Connect the park brake cable to the park brake lever on the caliper (1).
10. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
11. Lower the vehicle.
12. Start the vehicle and apply approximately 778 N (175 lb) of force three times to the brake pedal to seat the brake caliper piston and brake pads.
13. Refill the brake fluid. Refer to Master Cylinder Reservoir Replacement.
14. Burnish the pads and rotors. Refer to Burnishing Pads and Rotors.
________________
Let me know what you find and if this helps. If they are good, we'll move on to other possible causes. Here is a link, as well, you may find of interest:
https://www.2carpros.com/articles/car-pulls-right-or-left-when-driving-or-braking
Dec 13, 2020 at 9:52 PM
