brake fluid leaking from the brake master
2008 ACURA TL
113,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JMULL1126
I notices brake fluid leaking from the brake master can you help me change it out please?
Jul 27, 2020 at 9:45 AM
Here is a guide that will help with replacing this:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Plus below you will find the process from the manual.
Let's run through this material and let me know if you have questions. Thanks
Apr 1, 2021 at 10:04 AM
