Brakes and/or power steering
1995 CHEVROLET ASTRO
250,000 MILES • 4.3L • V6 • AUTOMATIC
JBROWNING11
The day after purchasing this van the brakes and power steering seemed to go out. Brakes go all the way to floor and there is no power steering. After doing some research I have discovered the possibility of it being the brakes booster. Is this a possibility or could it be something else? And if so, how expensive and how hard is it to fix? My wife and I are in love with this van and all the room it offers and would love to get this fixed ASAP if possible. Thank you so much!
Oct 4, 2018 at 6:20 AM
Good afternoon.
Did you check the fluids for the power steering and the brake fluid?
If you have a leak in the brake system, that would cause the low pedal.
If the fluid is low or the pump is whining, that could be the power steering issue.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/power-steering-problems
Oct 4, 2018 at 6:44 AM
