Brakes
100,000 MILES • 4 CYL • 4WD • AUTOMATIC
AJAANNEX6
My brakes are all the way up touching the dashboard. Something popped and now it is all loose. The cat still behaves as if its in brake mode, I can switch gears easily but it doesn't move. Its like I have my foot on the brake holding the car in place. Please help!
Feb 24, 2016 at 3:09 AM
JDL
  • 16,098 POSTS
If brake pedal mechanical issue, did you check brake pedal arm, anything the brake pedal arm touches? Check the arm for brake booster.
Feb 24, 2016 at 3:20 AM
AJAANNEX6
Thank you
Feb 24, 2016 at 3:27 AM
  • 55,746 POSTS
Please let us know what you find so it can help others
Mar 7, 2016 at 8:33 AM
