Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
MKX
Brakes
Caliper
Replace/Remove
What size Allen wrench do I need to remove the front brake calipers?
2017 LINCOLN MKX
99,000 MILES
VAF00
MEMBER
1 POST
Replacing the front brake calipers.
Feb 15, 2025 at 1:13 AM
Experienced Mechanic
I believe that it is a Torx and not an Allen. I attached a pic below showing the OEM slide pin bolts. I believe it is a 10 or 13mm.
See pic below.
Image (Click to enlarge)
Feb 16, 2025 at 12:25 PM
Add image or video
Ask a new question
Heater — Not Working
Cooling — Not Working
