brakes
134,457 MILES
AXLROZE07
I put new shoes hard ware kit and wheel cylinders on a few months ago just recently I lost the brake pedal I check for leas found nothing blead the brakes found air in the pass rear driver side was fine, had a brake pedal the next day went to drive it brake pedal wasn't there someone told me it could be the master cylinder could this be true
May 28, 2013 at 11:40 PM
DOCFIXIT
  • 18,828 POSTS
Yes if air is back in lines then master likely cause also check Pass wheel cylinder pull dusr boot back if fluid present that is problem
May 28, 2013 at 11:51 PM
AXLROZE07
Ok thank you I'll get back the with
May 29, 2013 at 4:46 AM
DOCFIXIT
  • 18,828 POSTS
So what happened?
Jun 4, 2013 at 1:40 AM
